Re: I found the command which was interesting to HP-15C. Message #2 Posted by thibaut.be on 10 June 2002, 10:37 a.m., in response to message #1 by Hiroshi Ito
I suppose that you want to show that the "ENTER" reg is not "clearable", at least by f CLEAR REG.
Actually by doing this you are "feeding" the "seed" registry of the f RAN# function, to generate a pseudo-random number. The "seed" is automatically regenerated when you use the f RAN# function, but in order to avoid always the same sequence (beginning with 0.1018,... if I can recall), it is requested to key in an aribtrary value by doing STO ENTER.
I don't have the 15C manual here, but I guess it is correctly explained in the RAN# function section.
Best regards,
Thibaut
