Re: HP 49G Question Message #2 Posted by Kenji Nagahama on 6 June 2002, 11:53 p.m., in response to message #1 by Jason Ketchel
Read Chapter6 of Advanced User Reference (AUR) first which you can get in HP's official site.
Since I also convert inch to milimeter and vise versa often, I created the following list in CST file for CUSTOM menu.
{ "in>mm" \<< '1_in' * '1_mm' CONVERT \>> } @ inch to milimeter
{ "mm>in" \<< '1_mm' * '1_in' CONVERT \>> } @ milimeter to inch
@ In your case, 'mm' should be 'cm'.
Store the above list as CST file in HOME directory and press L-Shift + CUSTOM. Then you will find your special menu for converting the above.
In another way to do, install UTOOL made by Carsten Dominik, which is very good unit tool.
http://zon.astro.uva.nl/~dominik/hpcalc/utool28.zip
