Re: Locktite Was: Re: Stick It! Message #6 Posted by Ellis Easley on 28 May 2002, 7:30 p.m., in response to message #4 by Ren
I don't know what kind Chris used, but my favorite kind of superglue is Loctite "Quicktite" "high performance superglue" which is a thin glue. What I like best about it (other than it sticks good!) is that the bottle cap has a metal pin to keep the spout clear. I've had the best luck with this kind as far as being able to use a bottle multiple times; with other brands, sometimes after one or two uses the cap won't close right and the bottle dries up. An earlier bottle of "the good stuff", that I kept for several years, did become quite thick; I then used it to glue my HP15C PCB back in place.
I recently bought a new bottle and didn't notice till just now that what I got is Quicktite but there is a brush built-in to the bottle cap, so no pin. I might keep it and see how I do with a brush.
The one with the pin in the cap is identified on the card as "reorder 79340-82193", that's just the UPC without the check digits. The kind with the brush is "79340-26442".
