Re: HP-41cx Message #6 Posted by Thibaut.be on 13 May 2002, 8:28 a.m., in response to message #5 by Spice_Man
Well, UMHO, ON / -> does solve the described problem but might cause some irreversible damage, even more prejudicious that the user apparently does not master his calculator. On my side I would recommend this operation only if other tries have been unsucessful.
I would recommend this setup (than can also be stored as a program) to "reset" the machine as standard use :
where @ is the [ALPHA] toggle and f the gold shift key
XEQ @SF@ 28 (or @CF@ 28) - . decimals (or , decimals)
XEQ @DEG@
XEQ @CLST@
f FIX 4
Of course many flags can be set/cleared to resume the intial state of the calculator, but I guess this short sequence solves most of the common problems.
