Re: Who made the first handheld graphing calculator? Message #6 Posted by Ex-PPC member on 8 May 2002, 11:35 a.m., in response to message #1 by aruid
It depends on how one defines 'graphing calculator'. If you
mean a large graphical screen with medium to large resolution, you are probably right.
But if it is defined to mean a handheld calculator with
an LCD dot-matrix display where the dots are individually addressable, you could consider the HP-71B, which has
a one-line, 132x8 display, and the Sharp PC-1500 (aka TRS 80
PC-2) which has a 156x7 display, though the Sharp PC-1350,
a later model (though still vintage) qualifies better as it has a much larger
150x32 graphical display while being smaller and much
lighter than either the HP-71B or the Sharp PC-1500.
