Re: HP-25 Bugs and "running" display Message #8 Posted by Andrés C. Rodríguez (Argentina) on 3 May 2002, 5:34 p.m., in response to message #7 by Ellis Easley
Ther "rorE" display appeared AFTER shaking the calculator (perhaps a false contact produced a un-sync somewhere), but remained there with the calculator not in movement anymore.
As per some digits (positions) showing faint "2", "1" or "0", I remember it had to do with display and angular modes. What I remember after more than 20 years may be incomplete, and also my English may be not the best to describe the phenomenon, but I think it was (more or less)as follows:
Mode..........Running Display
FIX...........-2#######-##
SCI...........-1#######-##
ENG...........-0#######-##
Something similar happened with the angular mode, but I am not sure about the particular position of the not-so-random digits. Or it may be the other way around...
The "program" to show such display is just an endless loop:
01.....13 01 (GTO 01),
and you should set the display and/or angular mode before running it.
