41CV -- access programmed lines outside global label? Message #1 Posted by Karl Schneider on 12 Apr 2002, 4:33 a.m.
41C "gurus" --
I just bought a 1986 HP-41CV. One "feature" I haven't figured out how deal with is a seeming inability to access lines of programming that were not preceded by a global label (e.g., LBL "PROG") On several occasions, I have entered a series of instructions followed by an END, then been unable to insert a global label in front of these lines using PRGM mode. CATALOG 1 shows the END statement for the incomplete program, and the memory indicators show that the instructions remain in program memory. However, I can't seem to access the set of programmed instructions or even delete them except with the master clear. I have not seen the an answer in the manuals.
This was, and is, not a problem with the 15C I've had for 19 years. I'm sure someone can enlighten me. Thanks!
Karl (15c, plus recently-acquired 41cv, 42s, 34c)
