Re: Is the HP-32E Display module the same for 34C? Message #2 Posted by Vieira, Luiz C. (Brazil) on 5 Apr 2002, 6:57 a.m., in response to message #1 by Luis
E aí?
AFAIK, they are functionaly equivalent. I have once replaced one 32's for a 34's, and it worked fine. I remember both calculators' circuitry was built sandwich-fashion, no solder, just flex circuit and IC's kept together with two metal clips joining the structure. The display assy could be removed and replaced without disassembling the assy.
Anyway, check the "replacing" component for it's code.
I know it is no concise info, but may help.
