Re: HP-32S: How do I close the casing again? Message #5 Posted by Paul Brogger on 18 Mar 2002, 11:15 a.m., in response to message #4 by Eric Edwards
Mr. Edwards:
I've taken apart just about every Pioneer model I own. They're easily made to stick back together, if you haven't drilled the upper heat stakes too deeply.
I just trim the mushroomed ends of the four lower heat stakes so they're just slightly larger than the posts themselves, and pop the sides back together again. (Don't cut the mushroomed ends off or shorten them -- just trim their widths so they squeeze back into the holes in the metal backing plate.)
The friction bond seems to stand up to most normal use. I dropped one once and one side separated slightly, but the halves didn't come completely apart.
If the top end doesn't stay together satisfactorily, you may use a soldering iron to melt the posts and holes together again.
The 32S is easily my favorite HP model for daily use. They're definitely worth the effort to keep 'em running.
I hope things work for you -- good luck!
