Re: Deliveries from Overseas Message #6 Posted by Glenn McEnroe on 13 Mar 2002, 2:10 p.m., in response to message #5 by Glenn McEnroe
I tried to send you 2 emails this morning Thibaut. I guess there is a problem with mail deliver. I received this response:
The original message was received at Wed, 13 Mar 2002 17:06:35 -0200 (GMT-0200)
from localhost [[UNIX: localhost]]
----- The following addresses had permanent fatal errors -----
<Thibaut.Cousin@bel.swatchgroup.com>
----- Transcript of session follows -----
554 <Thibaut.Cousin@bel.swatchgroup.com>... Cannot send 8-bit data to 7-bit
destination
501 <Thibaut.Cousin@bel.swatchgroup.com>... Data format error
----- Original message follows -----
Received: by tschaikowsky.eta.ch; (8.8.8/1.3/10May95) id RAA14832; Wed, 13 Mar
Received: from rwcrmhc51.attbi.com by tschaikowsky.eta.ch (smtpxd); id XA15902
Received: from rwcrwbc55 ([204.127.198.44]) by rwcrmhc51.attbi.com
(InterMail vM.4.01.03.27 201-229-121-127-20010626) with SMTP
id <20020313190801.MLGX2626.rwcrmhc51.attbi.com@rwcrwbc55>
for <Thibaut.Cousin@bel.swatchgroup.com>;
Wed, 13 Mar 2002 19:08:01 +0000
Received: from [199.89.163.190] by rwcrwbc55;
Wed, 13 Mar 2002 19:08:00 +0000
To: <Thibaut.Cousin@bel.swatchgroup.com>
Subject: RE: Time module
Date: Wed, 13 Mar 2002 19:08:00 +0000
X-Mailer: AT&T Message Center Version 1 (Nov 29 2001)
Message-Id: <20020313190801.MLGX2626.rwcrmhc51.attbi.com@rwcrwbc55>
Thanks for your reply Thibaut. I thought you might see
my email if I posted on HP Museum, because you recently
placed a classified ad there and I had not receive a
reply from you. I will let you know when the timer
module arrives and if you get some tracking info that
would be good as well.
Glenn
