Re: used HP28s or new HP32sii? Message #8 Posted by Paul Brogger on 7 Mar 2002, 11:22 a.m., in response to message #1 by Eric Mathers
Check eBay for current going rates on the -28S. Searching "Completed Items", for "*28S calculat*" (without the quotes) should work. I just checked, and it looks like the -28S seems to be going for $60-$70. There are at least three up for bid as I respond.
I actually prefer the -28S to the -48G, but they are more fragile. If you go that way, you'll want to ask about the condition of the battery compartment door, and expect to have trouble with it in any case.
The -32SII has apparently been discontinued, so it will become a bit harder to find. I like it for base conversions at the office and trig calculations at the workbench, but its programming is severely limited.
Good luck!
