Re: are you doing this from a c/cv or a CX ? Message #7 Posted by Chris Catotti on 28 Feb 2002, 2:35 p.m., in response to message #6 by db(martinez,california)
I assume it added EXTENDED MEMORY also. Check it on a CX with CAT 4. Should show 124 in the X Register. With one EXTENDED MEMORY MODULE, 362, or two EXTENDED MEMORY MODULES 600. You can also check it on a C or CV with the EXTENDED FUNCTIONS MEMORY MODULE by executing EMDIR.
David White (now David Ebras-White) use to do a lot of the soldering foe EduCALC and authored the "Butcher's Block" articles in the PPC Journal, which included a description of module doubling and tripling. See:
http://cgi.ebay.com/aw-cgi/eBayISAPI.dll?ViewItem&item=2005484928
for a little longer write-up
