HP Forum Archive 07
42 display
Message #1 Posted by JR(ITALY) on 22 Feb 2002, 1:17 a.m.
Can the 42s lcd display be replaced with one from a 17bii, any information is appreciated.
Thanks JR
Re: 42 display
Message #2 Posted by Frank on 22 Feb 2002, 9:24 a.m.,
in response to message #1 by JR(ITALY)
Real Answer is in this sites archives, from memory I think that it can.
Re: 42 display
Message #3 Posted by Paul Brogger on 22 Feb 2002, 2:07 p.m.,
Try the article at http://www.hpmuseum.org/guest/brogpion.htm.
Re: 42 display
Message #4 Posted by Tony Duell (UK) on 22 Feb 2002, 2:19 p.m.,
I've dismantled (and repaired) several HP42S and HP17B-II machines. The only differences between them are the keyboard markings and the ROM code in the `processor' chip (The big TAB one in the middle of the PCB). All other parts essentially interchange. The display swap should be fine. You may have 'fun' separating the display from the metal frame without breaking it, though.
