Re: HP 15C REPAIR - to remove bezel and other experiences Message #5 Posted by Ellis Easley on 28 Jan 2002, 4:32 p.m., in response to message #3 by doug
I can't really recommend this, but I found my 12C in parts, lying in the street. First I saw the button cells, then the bezel, then the rest of the calculator except the battery cover, which I found several minutes later when a car drove by and flipped it into the air and I heard a little tinkle when it hit the pavement.
The calculator must have been run over and this caused the bezel to pop completely off. This calculator worked except for one segment of the LCD when I put the found batteries in. Later I re-seated the LCD and it has worked fine since election day, 1988. The bezel was a little scuffed and bent. I bent it back pretty close and stuck it on with two pieces of scotch tape until I clean it up better (or find a good one)and attach it permanently with transfer adhesive. To get to the LCD, I cut all the heat stake heads to free the keyboard/PCB and then built up a pad from layers of duct tape so when I screwed the case back together, the PCB stays in place, although the keys are somewhat mushy as a result. I also freed the PCB on my 15C which had serious corrosion that caused it to draw more current off than on. In that case I reattached the PCB permanently by putting a tiny drop of superglue on each heat stake post, one at a time, holding each till set. If I ever decide to do this to the 12C I will build a fixture first to press the PCB into place so I can glue all the posts at once.
