HP-IL 82973A interface card help needed Message #1 Posted by katie on 19 Jan 2002, 7:47 p.m.
I have an 82973A interface card that I haven't been able to get to work in my PC (I'm using a 486 33MHZ for testing the card), the problem may be as simple as not having the right version of the software but I'm not sure. I have the CS80 program that comes with revision C of the 82973A board, but my board is revision A. I know that the address switch needs to be set differently on the revision A board, but I don't know if the software needs to be different. Does anyone know? Do you have the software that came with the revision A board?
Thanks,
Katie
