Searching eBay Message #2 Posted by Mike on 18 Jan 2002, 11:37 p.m., in response to message #1 by Erik Wahlin (USA)
You use "tomd" as an example. That suggests that you use this feature yourself. Nothing wrong with that. I suspect that if everyone was honest, they would admit they do also.
Also, eBay will never change that policy. Why? It benefits them. It makes for higher prices.
However, I have a tip for all.
You are very correct that the key to finding treasures is to search for the usual items by HP Calculator, HP Calculators, HP-XX, HP XX, brand, type, model, etc. But you also have to search by commonly misspelled words.
You can do all of this in less than 15 minutes, without relying on someone else finding something for you. How?
Whenever you perform a search, set a bookmark for that search. You can put them all in an eBay folder, for eBay searches.
Each day, you can go down your list of items, including all the misspellings and make all of your searches in about 15 minutes.
Each time you find a new query that work, add it to the list. No need to "reinvent the wheel" each time you want to look for something.
Hewlett Packard 15c
15C Calculator
42S Calculator
So, set a bookmark for each and run them both. Sometimes, you find things in one that are not in the other and visa versa, so it's a good idea to over search.
See how easy and fast that is. If you really want to get trick, you can create a web page that has every link you use and don't have to bother with bookmarks. I have a link to a page that I use, that has quick searches to just about anything you need. I may post a link to it.
There are ways to keep track of auctions without having to put up a bid that lets everyone know what you have found or running into the 20 mark limit.
