How to open a 34C? and battery? Message #1 Posted by Luca on 16 Jan 2002, 8:54 p.m.
My wife and I found an old 34C that she used before
buying a15C. I would like to clean it and restore it to use.
The battery pack leaked and caused corrosion in the
battery compartment. I will replace the batteries;
what kind should I use - are normal NiCads fine,
provided I get a good mechanical fit? We still have the
original adaptor.
Also, I would like to open the calculator to check
for internal corrosion. How do I do it?
I unscrewed the two screws located at the top, but
the case did not simply pop open: something at the
base (the short edge close to the user and to the
0 . etc keys) keeps the two halfs together. Do I
just need to pry it apart? I did not see screws
behind the rubber feet.
If I do find corrosion, how do I best clean it?
There was a thread on this some time ago, and I will
see if I can find it... any suggestions are appreciated,
anyway.
I will report on how it goes... Thanks,
Luca
