HP charger with different cells? Message #1 Posted by Ian Primus on 10 Jan 2002, 7:14 p.m.
I have a dead Woodstock style battery pack that I plan to rebuild, and I got it apart and removed the old cells, and bought some new ones at Radio Shack. I opted for the HI-Capacity Rechargeables, which are 1,000mAh as opposed to the 700mAh on the "Replace-a-cell" sets. Once I get the cells soldered together and re-inserted in the battery pack, how can I charge them? I have the HP AC adapter brick, as well as a separate little charger that just has a little light on it, and I have been using that for my other pack, but what happens if I use a pack rebuilt with these "High-Capacity" batteries? Will it just take longer to charge, or will it damage the pack/charger? Can I use this same charger if I were to replace the cells with NiMH ones instead of NiCad? Thanks.
Ian Primus
ian_primus@yahoo.com
