Re: Need a Card Reader Head for HP-97 Message #3 Posted by Tony Duell (UK) on 8 Jan 2002, 5:41 p.m., in response to message #2 by Andrés C. Rodríguez (Argentina)
The HP41 head will not fit easily. The heads are glues to the support plate, after being aligned at the factory. It's normal to have to replace the head and support plate (reader lower chassis, basically) as an assembly.
The HP97 and HP67 (and I think the HP65) all use much the same support plate, so you can interchange the entire
assembly. The one for the HP41 is totally different (although I think the head itself is electrically much the same -- certainly the same sense amplifier chip -- 1826-0322 is used in the 67, 97 amd 41.
