Re: Sting paper Message #2 Posted by David Smith on 5 Jan 2002, 5:23 p.m., in response to message #1 by Todd Garabedian
I saw a guy that built a splitter for the wide 3 inch wide NCR rolls. He took a block of balsa wood (3x3x12 inches), glued some pieces of plywood to the sides to form a trough, mounted a vertical razor blade in the edge, used another piece of plywood to hold the paper down in the trough as he pulled it past the razor blade.
An off-the-shelf source is Sav-On office supply. They have boxes of 5 (?) rolls (not as long as HP's) in their catalog. Most of their stores don't stock it but can get in in within 24 hours.
