Re: HP-71B ROM Transfers - Possible? How? Message #2 Posted by Reinhard Hawel on 5 Dec 2001, 3:39 p.m., in response to message #1 by Mike
PEEK$ prohibits peeking out of protected files. There were some special tools (for example a PEEK$ without this check) and some copy programs (I believe).
Normally you create a TEXT file in the same size, peek the data out of the protexted source file nibble for nibble and poke it into the text file. Then you change the file header of the text file to the type of the original file and you have a perfext copy. You can do this file for file.
Remember, that non-protected files can be copied simply with COPY.
This method doesn't work with the FORTH/Assembler and the translator ROM.
I can check my collection of software and send you such a program.
Is it a special module or one of the common HP ROMs ?
