Re: hp41 compatability today Message #2 Posted by Vieira, Luiz C. (Brazil) on 23 Nov 2001, 12:00 p.m., in response to message #1 by haga
Hello;
In fact, there is no calculator still in production that directly runs 41's applications. Anyway, some possibilities are:
1-41's emulator that runs in any 48G or 49; there is also an available emulator that runs in a PCM card, but I believe this card is available only for the S-series (48S/SX)
2-using a 42S - off-production, but available at e-bay or at classified ads at this site
3-far from a solution, the 32SII will run a few applications if correctly converted. Some 41's programs can be reduced in some steps if specific 32S' features are invoked
4-if time is available, any program written to the 41 can be rewritten to the 48. Some will be shrunk, others will need a complete, new version, as programming structure for both is not completely equivalent.
If you need to run an HP41 program in another calculator, let us know. For sure someone will help.
