Re: Quite True, Ross Message #1 Posted by Frank on 19 Nov 2001, 11:22 p.m.
Gene-Try the new version TI-BAII plus, much better keyboard, fortunate for your excellent book, same layout I think!
This is actually the 3rd version, as the original which I still have was called "Business Scientific" on the calculator. Major flaws in this thought possibly causing the renaming (more likely a marketing ploy)was and is no direct entry exponent (use y to the x) and no base 10 logs though we learned the Nat log conversion in the mid 70's I'm sure. Meanwhile, back to HPs while they last, anyway, and the old ones will outlast us all, unless the EL caps dry up first.
