Re: HP-97 Battery Message #9 Posted by Tony Duell on 7 July 2001, 2:02 p.m., in response to message #8 by Nick
Sometimes it's the simple things :-). It's good that the calculator itself is OK.
The charger is electrically very simple. A transformer. The primary winding goes to the mains, the secondary goes to the 2 pin connector that plugs into the calculator. The transformer, though, is a little special. It's designed to have a relatively high internal resistance
-- my measurements suggest about 11 Ohms (with an open-circuit voltage of about 12V).
It's worth doing a couple of tests on the charger -- measure the resistance of the windings (i.e. between the 2 pins of the mains plug for the primary and
between the 2 contacts of the calculator connector for the secondary, with the charger unplugged from the mains and the calculator). If either
tests opne-circuilt, crack open the charger case (this is not always easy...) and check the resistance between the connections at the end of the cable inside. Most of the time, the fault is
the cables, not the transformer. It's often possible to find the break or replace the entire cable.
