Re: HP-41CX clock quirk Message #3 Posted by Ion Abraham (New Mexico) on 8 Aug 2001, 1:27 p.m., in response to message #1 by David Smith
David,
I am fairly sure that this is not a "quirk," meaning
"it's not a bug, it's a feature." When the BAT indicator
comes on, meaning that the batteries are low, you no longer
have access to the clock. It's still running, but the clock
uses a lot of continuous power, so they made it inaccessible
under a low battery condition.
Note also that if you display the clock, the calculator
will no longer automatically turn off after a while, so that
is a sure way to run down your battery.
Ion Abraham
Albuquerque, New Mexico
