Re: Pac compatibility Message #5 Posted by Juan J on 25 June 2001, 7:03 p.m., in response to message #4 by Chris Catotti
Chris:
Thanks. Last crash ocurred after I was doing unit conversions with the Petroleum Fluids Pac. Then I solved an equation with the Advantage Pac. After that I tucked my 41 in my pocket for a moment. (The pocket was big enough to loosely hold it, with no risk of accidentally pressing the toggle switches and/or the keys.)
I turned the calculator on and did a sum. When I tried to turn it off it beeped while the display showed "0.0000." It refused to shut down. I subsequently removed the batteries.
After putting the batteries back, the 41 refused to turn on. I retired the battery pack again and carefully removed the modules. Then I put the batteries back and did a system reset: the 41 came back to life.
It has worked well after that. Every now and then, however, the Z factor corrupts the registers allocated to matrices, and base conversions leave unit data on the Alpha register. This made me wonder about incompatibilities. Since Z factor, unit/base conversions and matrix functions are system functions and cannot be copied to user memory, you can't "fool" the calculator in this way.
I have made intensive use of the extended function and memory without any problem so far. In my opinion, it is a significant improvement over the 41C/CV function set.
Finally, it is worth noting that both the Advantage Pac and the Petroleum Fluids Pac have system utilities (that's HP terminology for them) for some applications. As far as I know, most of the other pacs have programs written in ROM, not system functions. Label conflicts can easily be avoided, but what about system function conflicts?
Thanks and regards.
