Re: 9825 A vs B Message #2 Posted by Tony Duell on 8 June 2001, 1:48 p.m., in response to message #1 by Mike
I believe the -A could take either 8K(byte) or 16K byte RAM boards, with a maximum of 2 boards (any mix). This limited you to
32K bytes RAM, but if you had that much you couldn't use some of the plug-in ROM modules. So 24K was a more practical limit.
The -B has 1 memory board with 32K RAM, the system ROMs and most of the plug-in ROM functions on it. You can add a second special
32K RAM board, for a total of 64K RAM (not all of it is available, you get about 61K bytes free at power-up) _and_ virtually all the option ROMs.
I think the only ROMs not built-in are the Matrix ROM and the Floppy Disk ROM, and both of those can be added in the front-port connectors as usual.
Apart from the different memory boards, there are couple of track cuts on the CPU board in the -B to disable some of the address decoder circuitry on that board.
I may have got the suffix letters mixed up, but I know there is a 9825 with 64K RAM and almost all the ROMs built-in -- I have one. And I know that earlier models
have the system ROM module on the RHS of the machine.
