Re: HP Printer stuck Message #3 Posted by Tony Duell on 7 June 2001, 2:28 p.m., in response to message #1 by Robert
Yes, you can (and should) lubricate it. It's easiest if you remove the printer mechanism first -- open up the case (you've done this), slide out the window, remove the paper roll. Then unplug the motor
wires from the PCB, and carefully unplug the flexiprint from the printhead to the PCB. Undo the 3 screws and take out the mechanism. Clean the leadscrew and the printhead guide rods with propan-2-ol.
Lubricate the rods that the print head slides on with something like clock oil. DO NOT USE WD40. WD40 is not a lubricant, it will turn to wax in a year or so and will
really gum things up. You will then have real problems. Also put a smear of light grease (I use Electrolube Special Plastic Grease) -- it's expensive but worth it) on the leadscrew.
Work the print head back and forth using the leadscrew pulley. When it seems fine, put the belt back on.
If that doesn't do it, try a drop of clock oil on the bearings at each end of the motor.
