How to control the recieve bit in the HP48 as an input bit... Message #1 Posted by Tal on 18 Nov 2001, 2:55 a.m.
Hi, HP48 users!
Several months ago I built a data logger for HP48.
Since there is no availability of A/D converter to RS232
I had to build a "UART" (a parallel to serial converter),
and to use a parallel A/D.
Today some of my friends (a TI89 user) showed me a very
simple project (more so then mine) that does the same thing.
The site address is http://www.dvz.fh-koeln.de/~b012414/osci89/osci.html
I wonder how to control the recieve bit in the HP48 as an input bit
without using the RS232 protocol, (the transmit bit controlled by
the "OPENIO" and "CLOSEIO" comands.
I would be very thankful if you could help me and I hope its
not too difficult of a task for you.
Best regards,
Tal.
email: td@chem.ch.huji.ac.il
