Re: HP-97 f key Message #2 Posted by Tony Duell (UK) on 30 Oct 2001, 7:12 p.m., in response to message #1 by Pierre
I assume that the x2 key is the 'x squared' key, right?
Electrically, the HP97 keyboard is a rectangular matrix of keys. 4 columns and however many rows are needed (14?). The 2 keys you mention -- f and x^2 -- are not in the same row, and they're not in the same column.
Assuming all the other keys work correctly, there can't be a problem with the keyboard interface circuitry. ROM failure is, I suppose, possible (the machine could lose the routines needed to handle these keys, but _very_ unlikely. No, the only
likely cause is bad contacts on the 2 keyswitches, or broken connections (PCB traces, vias) to them. That's what I'd check first.
