48GX info needed Message #1 Posted by Jerry Doctor on 27 Oct 2001, 12:10 p.m.
Years ago I had an HP48sx. I got in during a promotion that got you a "free" equations ROM card. Also on the card was a Periodic Table with a massive amount of chemical data. I know the equtions library is built into the 48GX but have not been able to find out if the Periodic Table is. Can anyone help?
Re: 48GX info needed Message #2 Posted by Vieira, Luiz C. (Brazil) on 27 Oct 2001, 2:22 p.m., in response to message #1 by Jerry Doctor
Helo.
I was also sad noticing the Periodic Table is not built in the G-Series.
Re: 48GX info needed Message #3 Posted by Marx Pio on 27 Oct 2001, 6:18 p.m., in response to message #2 by Vieira, Luiz C. (Brazil)
Try http://www.hpcalc.org/hp48/science/chemistry/
It's for free and it really works.
Hope it helps
MPio
Re: 48GX info needed Message #4 Posted by Vieira, Luiz C. (Brazil) on 27 Oct 2001, 8:51 p.m., in response to message #3 by Marx Pio
Thanks, pal. I was not known about it.
(Valeu! Não sabia dessa. Ôh, deaparecido; por onde andou?)
Re: 48GX info needed Message #5 Posted by Marx Pio on 27 Oct 2001, 9:23 p.m., in response to message #4 by Vieira, Luiz C. (Brazil)
Andei meio ocupado com um projeto indstrial de +/- 6300 m2 de estrutura de concreto...
Abraços
MPio
Re: 48GX info needed Message #6 Posted by Jerry Doctor on 28 Oct 2001, 12:32 p.m., in response to message #1 by Jerry Doctor
As always the members of this forum quickly come through with the info I need. Thanks!
