Re: HP32sII display contrast Message #2 Posted by Harald J. Schulz on 24 Oct 2001, 10:58 a.m., in response to message #1 by William Pearson
> Is there some secret setting that allows one to adjust the display contrast on the HP32sII?
Not a secret, the Manual says "press and hold the ON-key, then press + or - to adjust the contrast" (translated from the german manual, so don't expect to find the exact phrase somewhere...)
> Should the battery indicator be full or empty?
It should not be visible, like the left/right-shift-annunciators if not pressed.
