Re: solve Message #5 Posted by Bill Smith on 4 Oct 2001, 11:01 a.m., in response to message #1 by Antonio Toledo
to add to the above discussion, excel does have a solver, as do lotus and quattro pro, though the implementation is a bit different from various calculator versions.
look under the Tools menu for Solver. There is extensive online Help. It is an optional install, so if it isn't present you can go back to Setup. Generally, you will select spreadsheet cells for Solver to adjust in order to manipulate the objective cell, which contains formulas or depends on the adjustable cells.
this should get you started solving.
bs
