Re: HP48 Message #3 Posted by Frank Travis on 3 Oct 2001, 10:31 a.m., in response to message #1 by Jimmy Cleveland
Your best bet is buying an HP48GX (expandable, 128K RAM, about $150) or HP48G+ (not expandable, but also has 128K RAM, about $100) from Calcpro website www.calcpro.com. I have purchased from Calcpro several times and have talked on many occasions to their manager, Paul Nelson. If you purchase the HP48GX or HP48G+ from Calcpro along with the PC Connectivity kit, you usually get a discounted package deal. My HP48SX (purchased in June or July of 1992 from then Educalc) was having problems turning on about February or March of 1998. I purchased the HP48GX as part of a discounted package deal from Calculating Edge (which replaced EduCalc, and has since been replaced by Calcpro). My HP48GX is still performing well. I bought an HP48G (not expandable, has 32K RAM)from Educalc in 1995. Some packages loaded into it cause MODE menus to lock up (probably because of only 32K RAM). I would like to get an HP48G+ and PC Connecity kiit in the future, and plan it to be from Calcpro. Good luck!
