Re: Self-test for HP-IL module? Message #2 Posted by Kim Holm on 21 Sept 2001, 2:57 p.m., in response to message #1 by Brian
Brian
I'm by no means an expert in this, but according to my recollection the best way is to connect the two plugs at each end of the loop (close the loop) and turn on the HP41.. - If the loop is good the 41c turns on almost instantly, if it's broken it takes a while, just as the 'open loop' takes a while longer.
Kim
