Re: MK install Message #2 Posted by Raymond Hellstern on 5 Sept 2001, 1:55 a.m., in response to message #1 by Dan Lamb
Hi!
Normally it should work,
if you follow the instructions in the readme.
Ok the readme is somewhat crude,
and you have to read it carefully,
and then try threee times before success,
but after all it will work.
The more difficult part is how to remove MK,
which is not described there (AFAIK;-)
Raymond
Note: These comments were not about MK functionality,
only about it's installation/deinstallation
