Re: HP42S - How to dump large blocks - Thanks, J-F Message #3 Posted by Vieira, Luiz C. on 29 Aug 2001, 7:45 a.m., in response to message #2 by J-F Garnier
Simple solutions seem to be far from a complex approach.
In fact, the auto-repeat feature is really the best solution. Just one more question: I will use a 48G running INPRT to receive the IR code, right? Will the DELAY feature be active in this case? As the 48 does not need time to print the lines out, there is no need for a delay after some lines. I will start doing it later this weekend, but if you have an answer already, I won't take time for testing.
Thanks again for your good suggestion.
