Re: Is there a current replacement for the Pana LCR-226P? Message #5 Posted by Tony Duell on 21 Aug 2001, 1:31 p.m., in response to message #1 by Tom Wade
I'm suprised I recomended another Panasonic battery, because such batteries are hard to find in the UK (the Yuasa brand is much more common here), so I'd not have ever used one.
However, there is a replaceent that will fit the 9114 pack and the Portable+, although it's less convenient to fit than the original. It is to use 3 off
2.5Ah Cyclon cells (these are cylindrical lead-acid cells about the size of normal D-cells, and are rated at 2V each). 3 of them fit perfectly in the 9114 pack or the Portable+ battery compartment.
You need to fix them together (hot-melt glue, cable tied, large heat-shrick sleeving), and wire them in series. Then connect the ends of the 6V battery so-formed to the original wires.
FWIW, both my 9114s (one a -A, the other a -B) have such batteries in them. And the Portable+ service manual shows a battery pack made from Cyclon cells, so they should be fine there.
Cyclon cells are available from RS Components (or Electromail) in the UK.
