Re: HP 38C repair Message #2 Posted by Tony Duell on 7 Aug 2001, 1:58 p.m., in response to message #1 by Kenneth MacKenzie
Older versions of the HP3xC and HP3xE machines were assembled with very few soldered connections. Instead the ICs and display pins were clamped againsta foam-backed flexible PCB using a plastic frame. And this design suffers from
bad contacts, causing faults ranging from missing segments to total non-operation.
Take off the back cover (ypu've already done this, right), and unclip the logic assembly from the top case (there are 3 plastic clips each side). Don't lose the keys, which are now loose
Then flip the logic assembly over (keyboard on top) and take off the metal clip strips on the 2 long sides. Lift off the keyboard/'PCB'. The display will probably fall off, if not, remove it.
Clean the PCB pads and the display pins with propan-2-ol (isopropyl alcohol) and put it all back together. That should fix the fault.
