Re: HP 48 G-Series Question: HMS to Degrees Message #2 Posted by Joe Panico on 26 July 2001, 11:46 a.m., in response to message #1 by Dan
Dan,
It's still there (you're correct). Many functions are accessed using the screen menu labels. That particular scheme can cause a "Memory Loss" ... your's, you can't remember where the function is located!
Try the left-shift, TIME, NXT key sequence and you'll find the function.
Joe
