Re: Is there a non-programmable RPN calculator? Message #2 Posted by John Ioannidis on 25 July 2001, 7:54 p.m., in response to message #1 by ryan watson
The only non-programmable RPN calculator currently being made is the HP17BII. It's a "business" calculator, with some math (but no trig). If you need trig and no programmability, you'll have to look on ebay.
I have occasionally seen the 32E being offered; that's probably the best scientific non-programmable RPN calculator. Other choices would be the 31E, 27 (extremely rare), 21 (rare), 45 (relatively easy), 35 (relatively easy, which is amazing given the age of the thing). You probably don't want the 35 in an exam, though; 2^3 is not 8, and it has a x^y instead of a y^x key; that will probably confuse you. The main problem you'll have with all these is battery time (oh, and don't neglect to rebuild the battery pack; 20-year-old NiCd batteries won't be holding much charge). LEDs draw a lot of power. You can somehow mitigate that by pressing the decimal point between calculations (or just turn it off if you don't mind losing results).
Good luck,
/ji
