Re: 82104A malfunction problem Message #12 Posted by Michael Tjebben on 7 Aug 2001, 11:53 a.m., in response to message #11 by Paul Hinrichs
Paul-
Yes. I posted a comment earlier this summer that I caused my card reader to malfunction with CARD ERR after having replaced the drive wheel. I surmized that the head got magnetized, because everything else seemed okay, and I got to thinking that as I was putting the screws in, they stuck to the screwdriver and I started feeling stupid!...
Demagnetizing the screwdriver with a torroid, and then the head with an old Radio-Shack head demagnetizer (they had them then) worked PERFECTLY!
Note, however, that some others posted later advice that it might be smart to unsolder the head to prevent induced voltage spikes from damaging the sense amplifiers. I did not to this, because I didn't think enough about this ahead of time.
You might search this site for those posts (not much more than 1 to 3 months ago, I think).
I did a quick search at www.radioshack.com, but was unable to find the same "wand-type" demagnetizer that I have, but they do have a small screwdriver magnetizer/demagnetizer that might help for that part of the equation.
A quick search using www.yahoo.com brought up the following,
which is very similar (though MUCH more expensive) than the
wand I have. This leads me to believe that with a bit more searching you might find something cheap and useful:
http://www.datadev.com/wd1.html
Good luck!
I bet the demagnetizing will correct your CARD ERR problem.
It did for me (and for my father's card reader as well).
-Mike
