Re: Why did the arithmetic keys switch sides? Message #2 Posted by John Ioannidis on 22 July 2001, 5:45 p.m., in response to message #1 by Dave Shaffer
This seems to have happened in 1981, when the 10C series was interoduced. The landscape-mode calculators had just four rows of keys, enough for the four arithmetic functions; it made sense to have the numeric keypad on the righ-hand-side of the keyboard (for the benefit of the righties), but it also made sense to have the +/-/x/: keys at the edge. Hence, the arithmetic keys switched sides. When HP went back to portrait-mode calculators, that change remained. This probably also has something to do with the fact that the ON switch was now just another button, at the lower-left corner of the calculator, where it has remained.
The other major change that happened with the 10 series was that the ENTER key lost its uparrow, as the key was now vertical and a lone uparrow would have been ugly. The uparrow did not return with the HP28, probably because ENTER was now not just a stack manipulation key.
/ji, feeling his Byzantine roots...
