Re: HP 82164A question Message #3 Posted by Hans Brueggemann on 16 Apr 2001, 7:05 a.m., in response to message #1 by Steve (Australia)
steve,
because the interface does not announce itself as a printer, the built-in printer functions of the 82160a assume that there is no printer on the loop. printing will work after issueing an XEQ 'MANIO' prior to printing, because this command tells the interface, that the user himself wants to handle the selection of the proper device on the loop. 'MANIO' will stay in effect until you reset the 82160a to its default state by XEQ 'AUTOIO'. if you have more than just the rs232 on the loop, you might need to address the rs232 manually by (x) XEQ'SELECT', where x is the loop address of the rs232, placed in the x-register of the stack.
cheers,
hans
