More than strange. Message #4 Posted by Steve (Australia) on 15 Apr 2001, 7:39 p.m., in response to message #3 by Mike
A data error? Where? Mine doesn't.
And I hope 32 also showed up as blank :-)
That's a VERY weird problem.
As a last resort I'd suggest opening up the calculator and looking for bad conections, but frankly, I don't see how bad connections could cause this.
The display of the HP41 is (from memory) controlled in 2 halves. Your problem is consistent with this in that only (and exactly) one half is affected.
The data in the alpha register is actually held in registers similar to the X, Y, Z, T, L registers, so it looks like they're OK and the problem is indeed a diaplay one.
It also affects operations other than the alpha register, since entering commands XEQ "XTOA" are affected, and (I assume) also program listings displayed on the screen, but not the printer (they should print OK).
