Re: Re; Hp-67 r/w head height adj. Message #3 Posted by Jeff Brown on 9 Apr 2001, 10:38 p.m., in response to message #2 by David Smith
dave, thanks for your suggestion. i thought i had it a couple of times, but by the time i glued it and retried it, it came up with errors again. am using a hot glue gun which holds fairly tightly but can be remved with an exacto knife. the latest attempt was to disassemble the card reading assembly, put a card in just the top part and try to let the head drop into position, where i then glued it. result was that when the part that holds the head was reinstalled on the rest of the board, too tight a fit ensued and had to start over. maybe your suggestion would be to put a card partly thru the card reader while installed and let the head just rest on the card, and then glue in place. am i getting it right? any idea if there is a factory manual that describes overhaul procedures? thanks for keeping up with this.
