Re: What I would do first Message #2 Posted by Mike on 28 Mar 2001, 4:56 p.m., in response to message #1 by D. Banks
What I would do first is to try and get the one that does not power up, to work, if posible. If you try to get one working from two bad ones, you might wind up putting good chips into a bad caluclator.
Second, damage to circuit traces does not stop the calculator from working unless they are completely disconnected. If they are simply discolored or partially damaged, that is probably not the problem.
Third, I would disassemble and clean each of the contacts in the connecitons between boards and at the LEDs. I have restored operation to bad calculators by simply doing this cleanup task.
Once you have one working, then swapping things to make one better one might be more realistic.
