Re: Opening an HP-21 Message #3 Posted by Paul Brogger on 27 Mar 2001, 7:59 p.m., in response to message #1 by Jonathan
If I remember right, the rubber feet near the display end of the calculator are inserted into rectangular recesses in the bottom case. These may be slid out, and a cross-head screw is underneath each. After taking out the two screws, the face comes away from the case at the display end. It is retained at the other end by a tab inserted into a recess inside the case, and comes apart easily. (Again, if I remember correctly!)
Good luck.
