Re: HP41 three prong Rechargable battery Message #2 Posted by Steve (Australia) on 23 Mar 2001, 10:28 p.m., in response to message #1 by Ty Rogers
No these are an earlier model of the same device.
The middle connector is actually part of a switch. You'll notice another piece of metal pushing against it. This contact opens when you insert the charger.
Beware. This version of the charger can output a much higher voltage to the calculator if the nicads are baddly deteriorated (to the point of being open circuit)
This charger is a little smarter than its replacement, but I doubt whether anyone would notice the difference.
In essence, if the nicads are OK then they are totally interchangable.
Another difference you might notice is that the models with 3 prongs also have a yellow (well mine are) plastic film over the ends of the nicads. The connection to the calculator is on this.
On the more recent version the ends of the nicads are the terminals.
