Re: Trig functions with small angles Message #4 Posted by J. Lopez on 22 Mar 2001, 5:11 p.m., in response to message #1 by Jim
Well, last night I compared the results of calculating the sine of small angles (in radians) in my HP-33C and an HP-49G. For angles less than 8.72664626 E-2 (approx 5 degrees), the difference between the two calculators was in the order of 2 E-12, which I don't think is significant.
Incidentally, for this angle, .087266 radians, the sine is .087156. These values tend to be closer together as the angle decreases. For example, when the angle is 3.49066 E-2 (approx 2 degrees), the sine is 3.48995 E-2 and when the angle is 1.74533 E-2 (approx. 1 degree), the sine is 1.74524 E-2.
The results given by a TI-92 Plus calculator showed better precision (typically one more digit than the HP49G).
